can you please help.I did a compression test,foun top cylinder was 85lbs & the other 2 80lbs,does anyone know what they should be.Removed old gasket & found it to be cracked,fitted new gasket still not running properlyalso spark plugs seem to be getting wet with fuel,could this mean it might need new piston rings?
