My 92' 30 HP (C30ELRQ) has a couple symptoms that I can't quite figure out. At WOT it never reaches peak RPM. No tach on my boat, but I'd say it's about 80% power/boat speed and audible pitch. Also, after a quick trip running WOT a couple miles, my 6 gal tank is significantly depleted.
If I squeeze the fuel line, the motor will rev up fully and everything seems peachy. My thought is that too much gas is reaching the carburetor, thus making the mixture way too rich regardless of high speed idle adjustment. To further exacerbate things, I torqued the head off the high speed idle adjustment screw
It is currently stuck in the fully tightened position, and I still have the same issue with excessive fuel and low RPM.
My (albeit newfound) understanding of the system leads me to think it's either the main jet, float valve, or fuel pump. Any ideas on where to start? I'm tempted to put a hose clamp on the main line and just crank it down till it runs right
. Seems like it should just be a quick adjustment to close down a valve a bit eh?
Thanks,
Daniel
It is currently stuck in the fully tightened position, and I still have the same issue with excessive fuel and low RPM.My (albeit newfound) understanding of the system leads me to think it's either the main jet, float valve, or fuel pump. Any ideas on where to start? I'm tempted to put a hose clamp on the main line and just crank it down till it runs right
. Seems like it should just be a quick adjustment to close down a valve a bit eh?Thanks,
Daniel
