Hour Meter install
  • Hour Meter install
    Good Afternoon,
    First off, new to the forum, and I have found some useful info. I am looking for assistance on installing a hour meter. I have a 2010 Tidewater with a Yamaha F150 on it.
    Here are the specs; http://www.tidewaterboats.net/bullet...cc-f150txr.pdf
    I purchased a Faria hour meter and installed it in the gauge panel;
    http://faria-instruments.com/cgi-bin...hite&id=MH0056
    I was curious if there is a place I am able to hook this up on the current wiring harnesses from the boat/Yamaha or do I actually need to splice into another wire that is powered by the ignition? If there isn't a place to connect on the wiring harness can I hook into the other gauges?
    Thank you for any help,
    Brian
    dont know how faria , italian for junk, wants it wired.
    but on the yamaha side yellow is key on power,dark green is tach send and black .
    is ground.
    had you ordered it with command link you would have all that nd more.
      Wish I knew the translation prior to purchasing it. Should have done some research and not bought what matched from the dealer catalog.
      Oh well, damage done. Did a quick scan of the meter last night and all they want for the meter is a 12VDC connection powered by the ignition. Is there a link where I can find the wiring diagram for the yamaha? http://faria-instruments.com/site_manuals/IS0011C.pdf
      Thanks for help and replies.
      Brian
        d.
        at the yamaha keywsitch, yellow is key on 12v+,black is groun
          Thank you for your assistance.
