On the 250 SHO Throttle Position Sensor (TPS), the component that is attached to the throttle cable...there is two alignment arrows ... is this the Full Throttle position?
Said another way, when you are at wot with your throttle, does these arrows align or does your throttle go past this point. If so does anyone know the reason for these arrows?
Thanks to all in advance.
