water pressure gauge
  • water pressure gauge
    anyone know what type of fitting i will need to put a water pressure gauge on a 200 hpdi, motor is a 2003
    you need the one yamaha sells.
    the block threads are metric.
    either 10mmx1mm or 10mmX1.5mm I cant remember.
    the fitting will screw into the port side top of the block.
      I believe the nut and ferrule kit for the Yamaha water pressure tubing is part number 663-83668-00
      I looked for the Yamaha fitting part number to install an aftermarket wp guage kit and finally gave up. The Yamaha wp gauge kit has everything you need.
        thanks i did call yamaha they told me the fitting will be a 14m by 1.5
          you called the wrong people.
          but do as you wish.
          the hex is 14mm NOT the thread.
          but do as you wish.
