My F 250 does not tilt all the way out of the water when raised. I have heard that , in that case , I should leave the engine down low enough so that the torque tab anode is in the water to prevent corrosion. So, is that the case and if so should I just leave the engine all the way down all the time? Thanks for any suggestions
What is the true answer?
I believe the answer to your question is: tilt the motor all the way up, as much out of the water as possible. If some of the skeg, lower unit, prop remain in the water, just leave it that way. Your prop and prop shaft are both stainless steel and your skeg is painted aluminum to be pretty darn corrosion resistant. I'd worry more about marine growths, algae, barnacles and such growing down there than corrosion. Good Luck!
