I recently replaced the seals on my 99, 100hp due to a leak. After replacing, the trim/tilt worked fine (would raise and lower and the engine would stay in place) but the engine would rise up out of the water when in reverse. I was told by my local marina that this was a valve issue. I cleared and replaced those. Now, the trim and tilt still works and will raise and lower the engine but when in the up position it will slowly drop and when I put it in the down position I can lift it. So, there is no pressure building up. I have bleed the system and filled with new fluid. Is this still a seal issue or is the piston shot?
Joe
Joe
