Hi,
I have 2002 4 cycle Yamaha on 19' C Dory, she was popping at 2000 rpm range i removed the carbs and clean them there was a plastic cap on one of the jets ? didnt make any sense, put the carbs back on the engine stars right up but little rough at idle if i lean the carbs idle improves but popping comes back if i richen the mixture idles rough but doesnt pop i check compression and every hole got around 110, pump some air into them didnt hear notting comming out, check ignition all of them firing , when i spray carb cleaner around intake manifold she stumbles and want to stall i dont think i have vacum leak anywhere, when i line the timing marks cams look tooth off , realy confused with this motor am i missing something any help be great thanks in advance
would be greatfull for a reply thanks Graham, UK...
