1988 90ETLG Carburetor Rebuild Kit
  • 1988 90ETLG Carburetor Rebuild Kit
    I am curious if the carburetor rebuild kit (6H1-W0093-01-00) contains parts for all 3 carbs, or just one carburetor.
    Do I need to buy one kit or three?
    Thanks.
    Terry,
    Good question - I looked up the parts diagram at both Yamaha and boats.net, and it is a little confusing.
    Since there are gaskets in the three carb setup that are common to all three (by that, I mean one gasket is shared by all three), I am pretty sure you need only one "carb repair kit". I've never heard anyone doing a carb overhaul on just one carb anyway.
    If you call the folks at boats.net (sponsor of this forum), then they can answer your question before you order.
    Good luck,
    Ken K
      Ken you are correct ,it is for all 3 carbs.
