Hi all,
I am new to the forum and have a 2002 Yam 115 EFI 4 stroke on a 02 hurricane 19 ft deck boat. I have had the boat for about 4 years and it has never idled quite right (stalls when coming off high RPM)
Recently it began to loose RPM and surge. It has gotten worse and will no longer plane out and sounds like it is missing at high RPM, under load. Out of the water, It idles at start up fine and sounds a little rough but mostly OK . Under load it runs very rough and sounds like it is missing
I do not think I have a fuel delivery problem:
Add new high octane fuel
Checked:
Tried squeezing the fuel bulb when running rough- no change
VST filter (tank and filter were clean no build up)
Fuel pressure at Rail (37-40#, no drop at any speed or while running rough)
All injectors are spraying (tested before reassembling Throttle body) and click when running
I think Compression is not a problem:
Compression (all reach 150-155# and hold)
I have some concern about spark:
All plugs deliver spark
The spark is more yellow with some blue, hard to see
Plugs 1 was pretty fouled (black) and 3 somewhat fouled
Load balance test did not show any cylinder that was not firing (out of water, not under true load)- when injectors are unplugged, one at a time, all drop the RPM a bit as expected
All ECM input sensors seem to be working:
Tested TPS (.75-79 volts at idle- resistance went from .880k closed to 4333 ohms WOT ), WTS (1.67K ohms cold), IAT (22.5K ohm slightly warm engine), and Neutral switch- all seem within spec
Hooked up a test light to the computer (l/wh and r/b wires)- no fault codes blink (I tested to be sure I was getting feedback from the computer by pulling the water temp sensor. The light blinked a 15 code, so I know it is working)
They could be out of adjustment, but none are flat out broke
Air- I have concern with the air and throttle adjustments, but do not know why it would have changed
I pulled the Idle speed control today and made sure the filter on it was clean. I found some carbon build up on the end of the stepper motor, filter seemed ok. When I put it back together at first it would not start- I found that it was being starved of air and would start fine, if I cracked open the throttle valves a bit. I think, at least at this point, the ISC is not opening to allow bypass air at idle. Maybe the ISC is mess up and is allowing air to by pass and mess up the air fuel mix.. Any ideas on how to test this??? I
I noticed that the throttle linkage( small bent rod with snap on ball joints) had the lock nut backed out. When I had it disconnected it might have turned, but the basic symptoms are still the same. Are any components in the linkage or throttle subject to failure?
At this point I think it is either spark or air. Any thoughts or hints would be a great help.
Checked:
