PUMP IN THE REMOTE TANK RUNS but does not supply oil to the motor tank. The little filter on the back of the remote tank replaced Tank removed and flushed out, installed and fresh oil added. Tank on motor, float sencer checks per manual . Emergency switch ok When key is in on position and switch is activated pump runs. When pump is tested it will run in both directions.
Book says to remove the little hose that conects the electric soliniod pump bolted to the side of motor to the VST tank run motor and oil should flow out that hose. It does not, however that hose only supplies oil to the VST Tank Was told by mechanic that the engine has to run quite awhile before any oil would come from that hose and that the electric solinoid pump rearely goes bad.
Does the remote tank pump have to be primed or will it pick up on its own ??
Does the little electric soliniod pump on the motor have any control in the filling of the motor tank ? Is there a test for this pump ?
