Help Upgrading 1993 200hp 2stroke to 2002 225hp 4stroke
  • Help Upgrading 1993 200hp 2stroke to 2002 225hp 4stroke
    Well I hit the lottery an fell into a brand new in the crate 2002 225hp 4-stroke (F225XTRA) a couple of weeks ago after my 2003 200hp V6 Yami blew up on me last summer. I got the motor mounted, oiler pulled, thottle changed out, multi-function gauge mounted and the ignition control harness reconnected. The tach and other control (trim/tilt) harnesses don't appear to directly convert from the 1993 to the 2002 technology. Any good resource out their for determining what harnesses I might need to make these final connections.
    Thanks!
    The 1993 multifunction tach and harness would not be compatable with a 2002 4 stroke engine, would need to replace it with 6YR-W0035-E1-00 Multifunction Tach kit and set the the tach setting to 4 stroke engine, 12 pole alternator and 2 wire trim sender.
