Spring tuneup time, boat sat for 5 months
Just changed bowl filter, medium pressure inline filter, cleaned VST filter but forgot to check regulator screen. I also just changed water seperator housing and filter and some of the fuel lines. new tank vent also. Drained gas from tank and put 10 fresh gallons in.
Then on first start
When starting engine fires right up but idles low and immediatly stalls.
If I try to add warm up lever it stalls. If I keep at it and bump throttle just out of idle it will stay running. Once I got it running I did check tps AND DID A minor adjustment to .59V, move throttle up and back a couple times it ranges from .61 to .59 in nuetral. Throttle plates are all closed at idle. Did notice some air at top of fuel bowl also primer bulb gets a little soft after start. Any ideas would be appreciated
Then on first start
