Only place I can mount this is near the bilge area. Can I cut hose from the tank to fitting comming out boat. Tank hose to seperator IN, then back up to hose Out. Am I going to need more hose. Who has the least expensive kit walmart?
Best place to mount water seperator kit?
I've had real good luck with the Walmart unit, just take your time and mount it where you can get at it to dump/change filter cartridge. It's a very, easy 2 screw installation, cut your lines carefully so they don't kink or rub on anything when motor is moving. Use only marine fuel lines, with clamps to hold lines onto fuel barbs. I've had mine about 3 years and so far, just unscrew cartridge, dump it out, screw it back on, anything that gets past fuel/water separater will get caught in on-motor fuel filter. Good Luck!
