Hi all it seems i've joined the not-so-exclusive club of 70hp owners experiencing no power under load.
Motor idles sweet on muffs..........
Have had carbies off cleaned thoroughly, replaced raycor water seperator, replaced inline filter from inside cowling, flushed tank thoroughly, replaced spark plugs ......
To begin with i could not get any revs over about 1500rpm - either in the water or with muffs, after cleaning carbs i can now get revs only with fast idle lever with muffs on, in the water it idles lower and will not rev above 1500 rpms.
Why will it rev up on muffs but not in the water??
Added to this i have now noticed water leaking from around spark plugs that was not present before and the telltale intermittently squirts water, when it does this water is very hot! have had hose off and cleaned it to ensure no blockages, water flow is still very weak.
Any help greatly appreciated, thanks in advance.
