Hi guys
Im new to boating and a complete novice when it comes to outboards. I have bought a surf ski boat with 2 x 55 hp 2 stroke 2 cyl yamaha's probably 1976 or 1978 models. I have replaced the impeller on one of the motors due to the "tell tale" not pushing out enough water and it seems that the engine is heating up a bit. The replacement of the impeller did not completely solve the problem and it seems that there might be some blockage in the system e.g. sand and/or debris.
Someone suggested that I should open the thermostat housing and clean it and flush the cooling ports (system) from the thermostat side with a hose. My problem is : Where is the thermostat housing located on the motor and is it possible to flush the system with a hose from there?
