Oil pump 87 Pro50LH
  • Oil pump 87 Pro50LH
    The oil pump is attached to the Choke plates, and it appears that they is very little movement of the choke plates and the oil pump lever. Is this supposed to be this way? If not any ideas why?
    oil pump linkage should be hooked to the throttle linkage not the choke.
    Check to see what is binding up if the linkage will not move properly
