I looked at the parts list, the C80 is Not a prime start even though some manuals say it is.
with no load the additional air can actually come from the ex ports to support a runaway.
thats why some modern engines and the old 2 cyl 35,33 and 40 big twins had a vacum switch to short a set of points if high intake vacum was present.
typically under a load as the throttle opens intake vacum drops close to 0"Hg or rises to atmospheric pressure.
with no load its possible to have 12-14"Hg in the intake and the RPM climbing.
thats why its not good to rev most 2 strokes on a flusher.
why it would not shut down with the key is odd.
could have been a very lean fuel mix that can act like a diesel and combust with compression.
usually the motor has to be almost at the point of overheat for that.
