My model # not listed in the Parts catalogue
  • My model # not listed in the Parts catalogue
    Hi - am new here and thought this would be a good place to get advice and buy parts. I have 2 x 225HP 4-strokes, but the model/serial no on the nameplates does not correspond to those listed in the Yamaha database. I suspect this is because I am not US based (living in the UAE), and the motors or probably Directly from Japan, but I would think the parts would be mostly identical and would like to be able to order direct from the US.
    Model FL-225AET
    Serial 69K-X-1008570 J
    Any advise much appreciated,
    Phil
    most parts are, however there were some differences.
    mostly with the ECM.
    drawback is here in the US I cannot access what changed.
    your numbers are for the international market.
      Cheers, thanks. Excuse the ignorance, but what is ECM? I have a parts manual for the AET which I downloaded and the part numbers are the same, so I think I should be OK.
      Another question- the fluid in the trim system is a milky pinkish colour which I think indicates water has got in. The main piston shaft has a slight scratch which i think is the culprit. Any other suggestions?
      regards
