Can some-one please help . I have a Yamaha 115hp V4 84 model, water is getting into the top right bank cylinder and the bottom left bank. Ihave replaced both head gaskets as well as the exhaust manifold gaskets x2, still water is getting in, any ideas. Don
yamaha 115hp 6E5
Water in Two cylinders
Exhaust plate has been cleaned and carefully inspected no cracks or pit marks on plate. Both heads have been carefully examined cleaned and no visable corrosion and V block, I can,t understand where the water is coming from. A little more info cylinder presures R 35psi, L 115psi, Bottom R 115 and Bottom L 45psiOriginally posted by rodbolt17 View Postcarefully inspect the exaust plate, carefully inspect the block at the V area.
the engine is simply blown up.
ex pressures from the working cylinders can and will force water into the non working cylinders ex ports.
in the intrest of not confusing simple minds like mine how about we use standard marine terminology.
starting with bow,stern, port and starboard.
bow is always the end usually pointy at the front, stern is always the aft end, port is always port,left side when looking at the bow, and starboard is always starboard.
port side engine bank are cylinders 2 and 4, stbd bank are cylinders 1 and 3.
can you post pictures of the cylinder walls on the cylinders with low compression?
