Guys,
I was running a 1984 9.9 in a barrel and noticed a stream of water coming
out of a hole above the cavitation plate. There are two holes on the left side (facing motor) and one hole on the right. These are about an inch above cavitation plate and are about 3/16" diam. I had a great stream coming from
water pump, but I also had a stream coming from one of the holes on left.
I am not familiar with this motor, so if you could give me a heads up on what this is I would appreciate it!!
