First posting on the forum- first Yamaha. I bought a flats boat several months ago with an '05 50hp 2stroke Model 50tlrd. It ran at 5200rpm up to a month ago at WOT. Now it wont go more than 3200rpms
Checked spark at all 3 cylinders with a spark tester at 3/8" gap at idle. Checked good.
Put Seafoam in tank (6 gallon plastic) & ran for a while at WOT & sprayed directly in carbs.
Changed plugs & thermostat & engine fuel filter. No help.
Squeezed primer bulb at idle & WOT per Seloc book to check fuel pump & boat fuel system to motor. No change.
Need help. Any more tests or ideas I can try.
Thanks ahead
Thanks ahead
