My F115 sometimes won't crank. It happened a couple of times at the boat ramp. I had it tilted up a little backing it into the water. Turned the key and nothing. Trimmed it down and it cranked up. Recently before leaving the house, I would test the cranking and no problem.
Yesterday while out, I turned the key and nothing. Turned it a few more times, placing the shift lever in and out of neutral and it cranked after about the 6th time.
I have checked all of my electrical connections. No corrosion anywhere. No loose cables. Retightened all of my connections.
Is there an adjustment for the neutral safety switch?
Or do they go bad? If so, where are they located?
What else should I be checking/replacing?
