I've got a 86'115. I'm getting 100-110psi in 3 cylinders and only 70psi in the 4th. I was getting 60 in the low cylinder but managed to get it up with a small squirt of pb blaster and 20 minutes of run time with a premixfuel mixed with a shocker dose of ring free. Am I on the right track? Is there something else I could do?
The reason I got into all this is because the last time I was out on te lake she kept cutting out at around 3000rpm. I'm thinking my injection pump is not working right and she's starving for oil @ the higher rpm range and it's over heating.
The plugs all looked the same, somewhat clean and little tan colored (good). This is actually different from what it ad been lookinglike before all this. They used to look a little oil rich.
My hunch here is something changed during thatlast ride. I.E. the oil injector pump is starting to fail.
Once I get through the ompression issue, I want to do a flow test. The book says 2.7cc@1500rpm per line.
Is there any words of wisdom out there for all this?
