I have recently purchased a used boat with a 2001 115HP Yamaha 4stroke model 115TRZ. I have read the sticky on winterizing and downloaded the 'Off-Season Storage Tech Tip'. These all advise not to run the motor out of fuel. However the owner's manual that came with the motor (March 2000 version) states "Remove the fuel line connections or shut off the fuel valve, if equipped. Run the engine at idling speed supplying fresh water to flush the cooling water passages until the fuel system becomes empty and the engine stops.
Which is the correct/preferred procedure and what are the reasons?
I would appreciate if this matter can be clarified for me as I want to do what's best.
Thanks for any advice.
