I have a 1990 yamaha 40hp ELD! It has been sitting up 5 years! It will start & run but won't idle! What would you suggest I do to refresh the engine".
To refresh an outboard
Originally posted by gsteel View PostI have a 1990 yamaha 40hp ELD! It has been sitting up 5 years! It will start & run but won't idle! What would you suggest I do to refresh the engine".
Check compression and hope for the best on the internals.
A good carb cleaning along with the fuel pump, lines, primer bulb, and tank to make sure trash / dried out fuel/oil will not hit the carbs and plugging up again after cleaning.
Don't forget to do the link and sync like your manual states after reinstalling the carbs
ÂÂ
