G,day
I have a 200 hp Yamaha 2 stroke 1995 i just brought it
and she over heats when you get into it after only about
5-10 min i have removed the leg and there are no blockages
in the pick up
so far i have replaced
head gaskets (no blokages in heads or bores)
water pump impeller (no excessive wear on plates oring sealing)
thermostats (have run without them and still overheats)
flushed with a corrosion flush
we ran it without the cover at 4700 rpm for about 10 min and no trouble
she seems to go good with normal loads just when you get up it it overheats
any ideas and help would be great
in the pick up
