about a month ago I picked up an 1987 yamaha 50 ELH outboard motor and finally got around to giving it a tune up and I have a problem. see below.
my problem is when i go to start it it starts and idles for 20 sec and then it chirps and dies. if you restart it it may run for a little longer then 30 sec and then it chirps and dies again. no clue why this happens.
I took the carbs off and had then rebuilt inside and out put them back on and no change the chirp comes back and the motor dies or slow's down but the chirp is there. now I have replace the spark plugs all fuel lines and it's still doing the chirp.
is there anything else I can check or replace to make the chirp go away??????
pssss. if this helps out in anyway if you put it in gear and give a little throtle it the noise goes away but put it back in idle and the chirp comes back
please any help on this matter would be great thanks
