Trim/Tilt went dead
  • Trim/Tilt went dead
    I have a 1991 200 Outboard.
    While underway, the trim/tilt switch on the throttle when activated
    caused the gauge to start flashing (3triangles) and beeping.
    Got back to the house and tested motor there.
    T/T worked for a few seconds, then went dead.
    Ignition also went dead after that. No sound when I
    turn the key.
    Don't know if it's the relays or the solenoid or both.
    If lost all power then may have blown a fuse on engine.
      where would this fuse be located?
        On the 91 it had inline fuses next to the starter solenoid.
          Thanks.
          What's happening now is ,the power will come back if
          I let the engine sit a while.
          It will give me enough juice to get a buzzing when I turn the key,
          but then goes dead again if I try to start or tilt engine.
