Command Link Hub - No Bus Cable?
  • Command Link Hub - No Bus Cable?
    I have a new F250 with CL square gauges and the electronic shift. The hub behind the console has the three device and power ports used but there are caps on the bus outlets. I want to hook another hub thru a bus and was unsure that it would work. Two of the devices are the gauges and the third looks like it goes to the helm. Advice appreciated!
    Warren
    Yes you can install another hub with a Bus Wire connecting hubs togather to install more devices.
