I just purchased a 1986 Yamaha 2 Cycle Outboard, used as a kicker on a small sailboat. The shift level was very stiff but it would shift. The other day the horizontal gear shift shaft broke with motor in neutral. (Part: 6E4-44111-71-EK). Is there a way to manually shift the engine into forward until I get the part and repair the shift lever? Andy
Outboard Shift Problems
Not sure what model you have but probably would have to disconnect shift lever activate shift linkage by hand.
Originally posted by swan34sv View PostI just purchased a 1986 Yamaha 2 Cycle Outboard, used as a kicker on a small sailboat. The shift level was very stiff but it would shift. The other day the horizontal gear shift shaft broke with motor in neutral. (Part: 6E4-44111-71-EK). Is there a way to manually shift the engine into forward until I get the part and repair the shift lever? Andy
I have a similar problem with a 1990 4SD but can't get the old shaft out of the housing - I think there is a single o-ring holding it. I pried the outer o-ring out.
Did you have any luck fixing yours?
regards, jimhanks
ÂÂ
