This justed started recently, when I turn the ignotion to the On position the alarm sounds. Could this be a short or grounding issue somewhere. Also, my dual batteries are low, could this cause the alarm to go off? I just hooked up my battery charger and the batteries were at 37%. I will charge up and see if this helps, but I am thinking might be another issue.
Yamaha S200TXRU Alarm in "ON" position
Mine has done this before it's just like a car. It has to be reset. I believe after a batt. Drops to 9v the arm will sound because it has to run the ecu computer. Turn power of for a few min at the batt switch then turn it back on and see if it resets.
ÂÂÂÂÂÂÂÂÂÂÂ
