I have had a continual problem with the carbs clogging. I have had the engine back to the dealer many times and have done all the recommended things.
Change fuel tank
10 micron filter
replace fuel lines.
Nothing seems to help. Every time it is the same thing. Idle is perfect and full throttle is perfect. It is the slow acceleration that causes the engine to bog down and die. When I pull the carbs and clean the low speed jet the problem is fixed.
Long one short, Yamaha mentioned putting larger jets in for the low idle the 50 HP uses a 62 and the 60hp uses a 65.
Can this done without many mods?
Change fuel tank
10 micron filter
replace fuel lines.
