This was posted on another site and I did not see a solution.
Yamaha F150 TLRD 2005. Having trouble getting on plane and staying on plane. Motor seems to be bogging and losing RPM. If I feather the throttle from WOT back a little bit then back to WOT the RPMs pick up and it starts too plane out. Once on plane if I keep feathering the throttle I can only get my RPMs to 5000 RPMs. If I leave the throttle wide open on plane without feathering it the RPMs slowly fall and eventually falling off plane. Motor cranks up and starts fine and idles great. I have checked the fuel already and the fuel filters and there doesn’t seem to be any water in the fuel. Any help would be greatly appreciated thank you.
From patterson307: One of my 2004 Yamaha F150s is doing the exact same thing (with the throttle "feathering"). Has anyone solved this problem?
New 2 micron Racors (old ones appeared clean inside).
Cleaned Fuel/Water separator under cowl (was not dirty).
Cleaned VST filter (was not dirty).
New Plugs (were not dirty).
