Does anyone know if the thermo switch on an F40TLRC can cause the engine ignition system to run retarded (Atdc) My engine runs 5* retarded @ idle, If i disconnect the thermo switch it goes to 10* retarded.
retarded F40TLRc
Is that cold or warmed up?
If that is while cold it sounds like it is doing what I told you on the other thread and You may need to recheck the specs in the manual for the 8 deg to be ATDC instead of the BTDC you are looking for.
Maybe some one else with a 4 stk manual can post on what their manual states.
ÂÂÂÂÂ
