#2 carb extra fuel line/ electronic Fuel enrichment
I have a 98 40hp 2stroke yamaha. It started to run badly I found the inline plastic fuel bulb/filter filled with stuff, I have cleaned/rebuilt all 3 carbs as well as the fuel pump. When i first ran it it seemed better but still only producing about 3200 rpm, I think closer to 40000 is normal. I remembered that there is a fuel line that go,s right from the 2 to carb to the cylinder that I has forgot to hookup, after i hooked that line up, it was back too only 2000 rpm? Could I have a problem with the electronic fuel enrichment valve , I wonder if I caped off that line if it would run normal, without the fee?
