I have a 2001 40TLRZ that seems to foul plugs frequently, the area that I run the boat in has quite a few long no wake zones and I have to run the engine at low RPM’s quite a bit. The carbs are clean and the motor runs great but after about 10 hours the plugs will have build up and the engine wont idle without stalling. If I put new plugs in it will idle fine.
Would it hurt to try one heat range hotter plug? B7HS-10 are the current plugs and it looks like NGK B6HS-10 would be the next hotter heat range. Thanks for the help.
