89 175 yamy 2 stroke, need help with timing
  • 89 175 yamy 2 stroke, need help with timing
    my 175, sat for a year going thru it, replaced filters water sep., plugs, seal on outdrive, was leaking oil out of oil pump replaced seal, after all that started a little rough found out the timing would not move at the top, wd40 and got it free, it idles and accelerates o.k, but i played around with the timing screw, i don't know what the timing should be now. any idea would be appreciated and practiced! should i leave it like that it seems to run fine have not had chance to give it a sea trial. I also played around with the carbs as the mixture screw was 3 turns on some carbs and 2 or more on the others, got them back to 11/2, seems to run o.k like that, my plugs came out very wet prior to playing with the carbs.any carb suggestions on sync?
    any ideas? trying to save on gas! and still going fishing
      Get A manual for that motor model is all the advice I can give
