My engine wont start without the prime start lever fully up.wont happen before i service all the three carb.Also hard to idle unless i have to tune its higher which is not usually as normal before i service the carb.Also hard and shaking to get it to plane but at higher rpm its good,Any suggestion?mine is yamaha 2 stroke 85hp
wont idle but good and higher rpm
Sounds like still have plugged passages or jets in carbs.
yes ,still have prob at the idle.sometimes during starting it start at one shot but sometimes its hard to start.and my other prob is the engine will shaking at low rpm and hard to get to higher rpm,once at higher rpm the engine was perfect.I have service the carb,new plug,new fuel pump diaghpram,new fuel filter,new fuel line and primer bulb,mixing ratio is as per factory manual.i hope u can help me
What is the air screw set at? Set it to the max according to your spec but first take them out and use a air hose and blow them out(dont have to take carbs off motor to do this). Blow in the hole you screwed them out of. Make sure the breather is off so you let the clog or junk escape. You have an obstruction in there.
ÂÂ
