hi all
iv got a 2002 f60 on which i got as a non runner (miss firing) on 759 hours.
i checked for spark, done compresion test and all cylinders were around 125-130psi.
next i went for the carbs, and after stripping the carbs down i found that carb 4 was coroded past repair, so i cleaned out the other 3 and got a whole new unit for carb 4. fitted , balanced ,serviced and every think was great for 30 hours running.
but last time i tryed to go out i primed the fuel went to start and it locked up. i popped the plugs out and found that cylinder 1,2,3 were full of fuel.
i took the carbs off and found that the was not much of a seal on the needle valves on the older carbs,so today i got some new floats and needle valves fitted them and now that operate just like the new carb.
iv now bolted the carbs back on and its running like a bag of nails, even though i have not touched any other settings
it needs full throttle to get started then once running the revs are unstable and if you rev it up it stays reving for 20seconds before it come back down.
i also noticed a leak on the top carb coming out the hole on the back of the carb near the top(facing air box) when you prime it on start up.
i tryed to balence to carbs but this just did not help. also at tick over the exhust is spiting out some fuel on the water like it running very rich.
iv took the carbs back off, but apart from checking what iv done i dont know what to try next??????????
please any help would be great as im lost and losing heart.
