got a 87 8sh motor cleaned carb. It runs but doesnt idle with choke off with choke on it will idle do you think it is the fuel pump not pumping enough fuel. It just seems like the engine isn't getting enough fuel and the primer bulb isn't staying hardhave to keep pumping it
motor only idling when choke on
not sure on that small hp but the other Yamaha's just took apart and cleaned, replace parts only if you find something wrong
I cleaned it very good but didn't replace anything other then gasket for the bowl do you think I should replace the float, I really cant tell if thats the problem or not runs good wot but just need more fuel when idling
ok called the dealer and got a rebuild kit on order and soaking the carb, company that makes rebuild kit is sierra are they pretty reputible
ÂÂÂÂÂÂÂÂ
