About six months ago, I started having low water pressure coming from the pisser and figured I had run in sand and mud to much and had to change the water pump impeller and it should be fine. I have since changed the entire water pump, including all gaskets and the plastic and aluminum water housings, you name it. I have changed the thermostat and pulled the inner and outer exhaust covers off and replaced gaskets, blow it out with air and checked to make sure that I have all water holes open. I have put all of this back together and placed lower motor in drum and it will not pick-up water still. I can place the water flush with hose on motor and with pressure from the hose, will get low pressure out of pisser. I have flushed entire water system with Salt Away. After flushing and starting again, I received no water from pisser and over heating horn went off. What can I do next????
I really need some help or I'll have to buy a new motor. Please help!
