Hi,
This is my first post here - so I apologize in advance if it is long. I am just trying to share as much information about our problem as possible -- with the hope that the readers can help us with our current situation.
We have a Scout 185 Sportfish with a 2000 Yamaha 115 2 stroke v4 - engine model C115TRY. My son and I were running it at top speed when it suddenly lost power and stalled out. When we restarted it we could hear something rattling around inside the engine so we turned it off and were towed back to port.
Rethinking the circumstances at the time we are not sure if the engine could have revved above 5500 RPM (redline for this engine) -- but that is certainly a possibility. If that did indeed happen we are assuming that this could have caused the breakdown.
I spoke with a local Yamaha service dealer and he indicated that internal noises are "not a good sign." This dealer has serviced other Yamaha engines that we have owned in the past and we have complete confidence in his ability. He then suggested that (worst case) it might need a new powerhead - but that can't be determined until the engine is dismantled to determine the actual cause of the problem.
The engine is in great condition and has been well cared for by us and the previous owner. However, we are faced with a real dilemma because the age of the engine and its actual value. We have to decide what is "reasonable" to spend on repairing this engine by weighing the cost of the repair versus the value of the engine due to its age.
He suggested we remove the spark plugs and check for any metal in the cyinders -- but none was found. We were able to start the engine and put it into gear - but we turned it off because of the internal rattling noises. The pistons, etc. seem to be OK because the engine does not run "unusually rough" like it would if there was a blown piston, etc.
We are afraid that if the dealer starts to dismantle the engine just to diagnose the problem, we are going to start down a "slippery slope" where we will end up spending a lot of money to fix this engine - and end up with spending more money to repair it than it is actually worth. We are mechanically inclined having completely rebuilt car engines and performed a lot of other repairs on cars, but we are not sure how to proceed here.
Having looked at some Yamaha engine schematics, and listening to the origin of the rattling noises while the engine is running - if I had to make an educated guess I would guess that there is a problem with one or more of the bearings around the crankshaft. We removed the carberator cover/air intake cover to listen more closely to the rattling noises - and the rattling sound seems to be coming from behind the carberators -- which is where the crackshaft and bearings are located.
The basic questions we have are:
1. Has anyone had experience with this kind of problem and can offer some suggestions of what the likely problem may be - and what is the best course of action to address it?
2. Is this something that can be fixed by dismantling the engine to identify what parts are defective -- and then rebuilding it to replace ONLY those parts?
3. If we attempt to dismantle and repair the engine --- are there other parts that we should plan on replacing while we are in there --- to avoid any future problems?
4. If we decide to repair the engine is it advisable to just repair/replace parts that are really defective - or is the dealer correct in advising to replace the entire powerhead?
5. Is there a reputable service facility where we could send the OUR powerhead to have it diagnosed and repaired or rebuilt for a lower cost than replacing it with a remanufactured powerhead through the dealer?
6. What sources do you recommend for getting discount Yamaha parts and/or quality Yamaha service --- at price savings that would justify repairing our engine - instead of replacing it?
Thank you for any and all assistance you can provide to help us with our perplexing dilemma ....
DIDG234
DIDG234
