I am helping a friend install a 2008 Yamaha 150 HP outboard. We received a wiring harness that plugs into the motor and goes up to the console. There the harness plugs into the Yamaha ignition switch and the Yamaha shift/throttle control. The boat has a tach and trim gauge we would like to connect up. Is there an additional wiring harness we could purchase from Yamaha, we checked with the boat manufacture and they only make a harness for Mercury. There was no additional wiring information that came with any of the parts. Any help would be greatly appreciated.
2008 Yamaha 150 HP
You would need 6Y5-83653-20-00 trim harness connected between engine and gauge to make trim gauge work and would need 6Y5-83553-No-00 gauge power harness that connects to key switch and to gauges for power and tach signal. If you are using aftermarket gauges then some trim gauges are not compatable with Yamaha trim sender, if this a 4 stroke engine then set tach setting for 12 pole alternator.
ÂÂ
