I have a 04 yamaha 200 hpdi that was not used for a while and it doesn't have any water flow from pee hole when running and when I hook it up to the hose to flush the motor no water goes through the motor at all.
not able to flush motor
Originally posted by eric.101 View PostI have a 04 yamaha 200 hpdi that was not used for a while and it doesn't have any water flow from pee hole when running and when I hook it up to the hose to flush the motor no water goes through the motor at all.
Hope this helps. Good Luck to ya!
thanks for the reply I will try hooking the hose up to pee hole and flushing from that point today.I dropped the lower unit and hooked hose up to flush connection and still no flow, the hose actually popped off where the flush connection connects bellow the motor from the presure of the hose because there was no flow. I tried sticking a thin wire in the elbow that hose connects to but wont bend through elbow. Disconnected hose from pee hole and removed blockage from there.Any more sugestions if flushing from pee hole doesn't work.
Originally posted by eric.101 View Postthanks for the reply I will try hooking the hose up to pee hole and flushing from that point today.I dropped the lower unit and hooked hose up to flush connection and still no flow, the hose actually popped off where the flush connection connects bellow the motor from the presure of the hose because there was no flow. I tried sticking a thin wire in the elbow that hose connects to but wont bend through elbow. Disconnected hose from pee hole and removed blockage from there.Any more sugestions if flushing from pee hole doesn't work.
ÂÂÂÂÂÂÂÂÂÂÂ
