Yamaha Gauge adapter - 6y5-85335-10-00, 1 or 2
  • Yamaha Gauge adapter - 6y5-85335-10-00, 1 or 2
    I have a 2003 Yamaha 4 stroke and just received replacement Yamaha digital gauges, Tach and Speed with kit part #6yr-w0035-f2-00.
    I understand I need an adapter part# 6y5-85335-10-00. Will this part # include one adapter or two? One for tach and one for digital speed? Or will I have to purchase 2 adapters? Boats.net do you have this part?
    Greg
    You only need one adapter that will installed on engine to adapt the 2 connectors on engine to single connector on harness that came in kit. There will be a black wire on adapter that needs to connected to engine ground to make it all work.
      Do you have a diagram that you can PM me, or provide a link? Thank You
      Greg
        No don't have any diagrams for that adapter but it is marked which end to connect where.
          Help please!!
          Im having the same situation, I have 2, 225hp four stroke 2003, and I'm trying to install the same gages, the local dealer keeps telling me that the adaptor part number I need is 6y5-85335-00-00 and just by looking at the connections it does not make sentence at all. So when I looked on the web I found your post, which has a different part number adaptor 6y5-85335-10-00.Did it work for you? I would really apreciate some help!!
          My email is jp0119@gmail.com
          Thankyou!
