Originally posted by makomagic
View Post
If using a lazer temp gun, (we did NOT), point at the lower BLOCK/cylinders/water jacket, near the head, especially the lower 2 cylinders on each side and compare temps higher up the block.
We had the same issue with my neighbors v6 200. (he didn't flush regularly, if at all). The lower two cylinders were about 90% clogged with hardened salt, thus, almost no water flow (which happened to be near the sensors). After cleaning 3.5" of salt out, ran like a scalded dog, no shut downs.
BTW, these links may be helpfull and worth a read;
http://www.yamahaoutboardparts.com/f...g-th19434.html
http://www.yamahaoutboardparts.com/f...m-th23666.html
Good luck and please post you findings/fix...
