Hello,
we are having problems with a 1998 Yamaha 25 hp 4 stroke outboard that has been regularly serviced and running great until recently.
A week ago it became very difficult to start the motor and would only start without using the choke and if you touched the choke the engine would stall and even when if you dont touch the choke it would stall after 10 or 15 seconds.
Yesterday we had to tap the side of the starter solonoid to get the starter to engage because it started making a clicking sound and even then the engine wouldnt run for long and after having checked the plugs they are clean and not fouled up at all.
Then the weirdest thing happened while trying to start the motor we turned off the key and removed it from the ignition but the engine kept on cranking and had to turn off the battery switch to kill it.
There is plenty of fuel in the tank and the pump is delivering fuel to the carb so i dont think it is that.
As usual any help or suggestions will be greatfully appreciated.
best regards,
Doug.
best regards,
Doug.
