30hp motor overheating
  • 30hp motor overheating
    Took the runabout out in the weekend and noticed not much water was pumping out and sometimes would stop all together and the overheating light came on....does it need a new water pump or is it something I can fix.
    ross,
    Check the water pump intake to make sure it is not clogged up - if it is ok, then it's time for a water pump repair. If you are mechanically inclined and want to do it yourself, go to www.yamahapubs.com and get a Yamaha shop manual. Go to www.boats.net for your water pump kit.
    Good luck,
    Ken K
