Charter fishing on Lake Michigan
There has to be a better way to test the 02 sensor after cleaning then the torch test – is there anyway to send a unit back in have it rebuilt – at 270 dollars replacement is costly reinstalling the old unit only to find it will not perform correctly makes for labor & gaskets wasted. I ***** close to idling speed for 5 hours and the have about a 20 minute run back in to port - the water in spring is usually below 50 degrees – I do use ring free – the fuel has lots of additives – I remove and clean the sensor each year, and if it not working will spend the money for new ones but hate to do the work twice but not as much as buying two new sensors each year
